Should I go with disk brakes or not?
Discussion in 'General Maverick/Comet' started by Bigh4th, Mar 10, 2004.
  1. Bigh4th
    Bigh4th Member
    Dinwiddie, Va
    70 maverick grabber
    Ok, i'm getting ready to start the "fix-up" process on my 70 grabber. Right now it has a 250 in it but i'm swaping to either a 302 or 289 (haven't decided which yet).
    Now I don't plan to drag race it, but it's not gonna be a trailer queen either. Right now it has manual drum brakes and 4-lug suspension.
    Am I gonna run into any stopping problems with the drum brakes or any problems with the 4-lug axles?
    -Harry
  2. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    Yes, put the disk brakes on!!!!! While you are at it get the rear axles off a 5 lug. You wont regret it...
  3. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    let me be next in what is going to be a long line of mav folks saying "DO IT!" put in the rear axle too! once you make the (right) decision to switch, fumble through here. somewhere there is a thread on "how to" and "what to buy"
  4. Bigh4th
    Bigh4th Member
    Dinwiddie, Va
    70 maverick grabber
    well....
    I've already got a 75 two-door junker that has disk brakes and a 3:00 rear. The only thing I'm worried about is that i think (haven't looked yet) that the 75 has staggered shocks where my 70 doesn't.
    what should i do about that?
    Basicly i've got all the parts i would need, i just don't know if it's worth the trouble or not.
    -Harry
  5. Earl Branham
    Lugoff, SC
    Big4th; doesn't matter about the shocks. The shocks will mount either way, just put them in the way they came out. The 8inch gear was made for the body, and bolts up perfectly. I have a 69.5, and the brakes and rear are from a 75 Comet. Easy to do, much safer, and you have a choice of better wheels to choose from. Good luck and take care, ask if you need help.
    Earl
  6. Bigh4th
    Bigh4th Member
    Dinwiddie, Va
    70 maverick grabber
    I see. Well I guess i may have to swap them over then. I just hope the junkyard's rollback can pull the car up without and axle or front wheels.
    -Harry
  7. bmcdaniel
    bmcdaniel Senile Member
    non-staggered shocks
    My '70 doesn't have staggered shocks either, I ended up using early Mustang shock plates. The shock mounts are at a slightly different angle than what a Maverick needs but they'll work. I cut mine almost all the way through, bent to get the right angle, then welded them back together.
  8. GrabberMav71
    GrabberMav71 Member
    Kentucky
    1971 Maverick Grabber
    well, i would normaly say just go with the disks, but, if it is just going to ba an everyday driver i dont see why it would really matter. i have manual disk brakes on my mav and like it, but my dad has a 9.7 second @140mph '68 mustang that runs full drums and it stops fine, so......i dont really know
  9. jpollard
    jpollard Member
    Montana
    Running in heavy traffic is much harder on the brakes than running a 1/4 mile. Try running down the streets of seattle and stopping at every light once and then see how well they work. Once those puppies heat up you can have problems. Even without hard stop and go the disc brakes will work much better at stopping you. There are drum brake systems out there that work pretty good but the Mavs are not one of them. Go with discs, its a pretty easy conversion.
  10. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    I know what you are saying, but for me doing the switch is not only safer, but I think of it as increasing my defensive driving capabilities if you know what I mean. The way others drive, it just helps to have some extra braking power. So, if you care about your own safety and the condition of your car I say do the swap. :)
  11. Bigh4th
    Bigh4th Member
    Dinwiddie, Va
    70 maverick grabber
    Well, i'm gonna do it. I'll snatch what i need off of the car this weekend.
    I was leary of it because i wanted to try to keep the car as original as possible, but since i've got the ford motor company wheel covers, no one will know anyway.
    -Harry
  12. scott
    scott Member
    new jersey
    you go dave!
  13. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    If your Mav has an 8" in it, just use the existing shock mounts & spring plates as the diff does not know what year car its in and the spring plates don't care either.
  14. Bigh4th
    Bigh4th Member
    Dinwiddie, Va
    70 maverick grabber
    Cool. My 70 does have an 8" rear and I hoped that would be the case, but i never got under the junker to compare.
    I'm just pulling the disk conversion parts off of the 75 junker. I'll snatch the rear end out of the 73 4door i got from the junk yard. They're both 5 lug and have the same 3:00 ratio. I just wish one of them was a locker, but my understanding is ford never put limited slips in a maverick.
    -Harry
