Should I remove old gas after storage???
Discussion in 'General Maverick/Comet' started by Bird, Nov 11, 2012.
  1. Bird
    Bird New Member
    Eugene
    1970 Ford Maverick
    Just taking my 70 Maverick out of garage storage after 3 years.
    How do I drain out all the old gas?
    Should I clean/replace the fuel lines as well? I was warned by multiple people about a possible fire hazard (from the alcohol in the gas possibly eroding the lines).
    I want to make this car safe and reliable for my son... Any suggestions on where to start?
    Thanks,
    Brad (Bird) Leonard
  2. 71gold
    I would remove the tank, drain/clean it out. then would be a good time to install a...drain plug...:thumbs2:
  3. Krazy Comet
    If the gas has a rancid odor remove the tank, otherwise I'd siphon as much as possible then add fresh fuel... Do check condition of rubber lines...
    Note fire is always a possibility with gas, I recommend doing any work or siphoning OUTSIDE...
