I have the ldo side trim and at one point it had a halo top now its just the trim. i took the trim off for the halo top when i primered it and now it doesn't go on right and its just annoying, now im wondering if the side trim is going to be the same way and if not, then whats the right way to remove all the little tabs for the trim?
You have to be really careful not to twist the halo top trim, it's pretty soft. I guess it all depends how you took it off. To remove the tit's, you can grind them off, of twist them off with vise grips.
yeah im talking about the trim on the side more then the top i actually took one side off part of the way and didnt finish because of it.. if i twisted it off would i be able to sand it smooth of would it be all chewed up where they were?
Sometimes they will come off clean, but they might need a little clean up, but much less if your not careful grinding them off.
