Similar Bumpers?
Discussion in 'Parts Interchange' started by MarulMav, Jan 23, 2006.
  1. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    Anyone ever seen the similarity between the 70/71 Mav bumpers and the 70/71 Pinto bumpers? Anyone ever try this change? Are they the same size? Hope you don't think I'm :coco: for asking.
  2. Jamie Miles
    I believe Maverick73 is running a Mustang rear bumper on his car.
  3. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Jamie is correct, I am running a 67/68 Mustang rear bumper, it did take some slight mods to make it work, I had to drill new holes in the factory bumper brackets, this will only work with 1973 Maverick bumper brackets, 70/72 Maverick bumper brackets will not work because the bumper must be pushed in closer to the body and the fillers at each end of the car prevent this because the Mustang bumper end openings are not large enough to accomidate them.
  4. Craig Selvey
    I bet the 1970-1972 Bumper mounts would work if you used the 1970-1972 lower rear quarter extensions.....which are smaller than the 1973 lower rear quarter extentions.
    Either way......I want to say:
    :ttiwwp:
  5. Mavaholic
    The Maverick Bumper is wider than the Mustang so the ends will not quite line up in the center of the quarter extensions.
  6. sierra grabber
    sierra grabber Certifiable
    northern nevada
    the 68 cougar looked VERY similar as well. but was much wider in reality
  7. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i made some brackets to mount the 67-68 mustang bumper. the mustang bumper is flush on the ends.mustang bumper not as tall as maverick bumper. changed mine back the fender extensions did not line up right. i do like the idea of being able to buy a rechromed bumper for under $100.00
  8. papawdarrell
    papawdarrell papawdarrell
    Arkansas
    1973 Maverick
    Did I read this wrong:hmmm: , I thought he was asking about PINTO bumpers:huh: Where did all the Mustang stuff come from:confused:
  9. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I know nothing about Pinto bumpers, however the 69-70 Stang rear bumper looks very close!
    I would have thought it too wide, but the rear valance is supposed to swap according to some that say they have done it...
    Dave
  10. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    Couldn't have said it better myself!!;) Thanx
  11. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    It's too short, I tried one, now I need to get rid of it:hmmm:
  12. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    Are we talking about the front Pinto bumper? Looks the same but will it fit??
