Skinny Bumper Swap
Discussion in 'Technical' started by NCFatBoy, Dec 3, 2015.
  1. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    What is the best method for getting the big bumper bolts out of the frame?
    The nuts don't seem too accessible.
  2. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    The nuts are typically spot welded to the frame I believe. When I removed my 73 brackets one of the nuts broke loose and I had to cut the bolt. Had a heck of a time getting that nut out...
  3. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Mine are spinning....
  4. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Update, only one is spinning.. it's the one closest to the hole in the frame. Hoping I can still get it out. Going to try tomorrow.
  5. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Ok, got that one out, but the front on the drivers side spun also. Just finished grinding it off. I've read where the bumper swap requires notching the fenders, I'm assuming that is for the stone guard to fit?
    Also, I thought I read somewhere that the holes for the skinny bumper were already drilled in the frame in many cases, not on mine. There's a back hole that may lineup, but no others.
  6. William623
    William623 Member
    Orlando
  7. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Thanks for the link!
  8. 71gold
    what year car? these are the measurements on my 73'...
  9. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Mine is a 73. I have it bolted up in the existing hole, just to see how it fit... Thanks for the measurements. I still have to notch the fenders. Trying to decide the best way to cut and especially bend the notches.
  10. 71gold
    cut on the first line and fold on the second one.
    my fender had an imprint on the inside where to fold...like it came marked from the factory to notch...:yup:
    NCFatBoy likes this.
  11. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Thanks, I'll have to look for notches....
    So, the top bend looks like it's at the bottom of the headlight bucket.
  12. 71gold
    closer to bottom of the headlight bezel...
  13. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    That's what I meant... LOL...
    Not seeing any imprints on mine... I get out a level tomorrow and figure out with a string how much to cut I guess....
  14. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Notched the stone guard. just bolted up for fit, still have to drill the bracket holes in the frame.
  15. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    I'm having trouble finding Stainless Carriage Bolts for the bracket to bumper bolt up. Where are you guys getting replacements? Or new stainless?
