Got the E.T. streets put on the mav today. fixin to load it up on the trailer for tomorrow. anyone close to steele alabama come on out. anyone wanna throw some time guesses? gonna run 1/4 comp 292 cam torker 289 intake 60 over flat tops 750 holley 3500 stall 380 gears
Whats the car weight,and do you have subframe connector and whats done to the rear suspension,what compression is the motor,
compression somewhere around 11:1. stock suspension. i ran it before i got the gears and the big stall. it started clanging real loud when i stalled. so i nailed it. hoping it would just blow up since i was mad. pulled back to the pits and pulled the passenger valve cover and the front 4 rocker arms hit the ground. ran a 13.20. havent ran it since then
Well it should run a little better with the rocker arms back on Good luck and have fun, we might have to drop our guess a little lets say a 12.85 but hope you do better than that
well itll be after this weekend before we know. got rained out today. ORSCA is gonna be at steele this comin weekend so i cant run then. i hate the rain. car was loaded and i was on my way. bottom fell out and they called it off
