slipping C4
Discussion in 'General Maverick/Comet' started by NWMO_Maverick, Jan 17, 2017.
  1. NWMO_Maverick
    NWMO_Maverick Member
    Northwest MO
    1976 Maverick 302, C4
    Hey all,
    Inquiring about a 76' Maverick with a 250 and C4. Owner indicates the transmission works when cold, but slips to uselessness upon warming up. What are the chances a servo adjustment ?? might solve? 1/10? I see rebuild kits on ebay and while I haven't messed with a transmission before, these sound similar to a motor rebuild, which I feel comfortable with.
    5-bolt with a clean 250, asking $2,000.
    Chris
  2. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    smell the tranny fluid to see if it smells burnt. It should have a dark red tint. If you see metal particals in the fluid try an get him down on price. These trannys to rebuild only cost 300.00 with a reman torque converter.
  3. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    In my area at least you can't get a good rebuild for less than $500.
  4. 71gold
    if it's never been rebuilt...it's time for one...:yup:
  5. Krazy Comet
    Even the best engine rebuilders are generally lost once inside a automatic trans... At least have to do some studying...
    Years back I rebuilt a couple C4, isn't really difficult just have to be CLEAN and keep parts organized... I swept out garage and covered floor with paper, when I got it apart I had a life size, exploded view just like in shop manual...
  6. NWMO_Maverick
    Northwest MO
    Thanks all,
    We'll get something figured out one of these days.
    Chris
  7. Craig Selvey
    This is not a task for a novice. It takes specialized tools.
    mojo likes this.
  8. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    ...just in case, but I'm sure that you already checked.
    If you have low fluid, it's sometimes possible that you have transmission engagement when you first start up, but as the transmission fluid pump fills all the cavities & galleys, there isn't enough for the fluid switches & torque converter.
    Always check when warm & running.
