slow overheating?
Discussion in 'Technical' started by Cameron, May 3, 2014.
  1. Cameron
    Cameron Member
    oklahoma city
    1977 Maverick
    Car:
    1977 ford maverick 4 door 302
    mods:
    Edelbrock performer intake manifold
    Holly racing 4 barrel 650 cfm carb
    Newish auto zone water pump
    Brand New 3 row aluminum radiator
    Stock fan set up (direct drive)
    sheet metal shroud (custom one I made)
    Delete of A/C compressor and hoses
    Issue:
    Okay so my car had this weird bogging sensation so my friend and I went through my carb and found this tiny bug that was clogging my fuel and fixed it. Car started working fine.. the next day I randomly had this slow overheat like the vehicle instead of chillin at 190 should slowly move in increments of 5 degrees and heat up to like 230. so I get out cool it off without the radiator running it would get to 250. Not good. took out my thermostat put it in water to watch it open at 190 it did its job. now im running without the thermostat and I have the same issue. I dont believe i see any signs of a blown head gasket but im here again. No antifreeze coming out of the weep hole. Id go get fans but like i said she ran well with the same set up and i never had a problem. Im kinda out of ideas on what she may be.
  2. Dave B
    Whats your shroud look like?
  3. Cameron
    Cameron Member
    oklahoma city
    1977 Maverick
    This is what it looks like
  4. Cameron
    Cameron Member
    oklahoma city
    1977 Maverick
    Its just cut and bolted sheet metal
  5. Cameron
    Cameron Member
    oklahoma city
    1977 Maverick
    I get good airflow
  6. car-nut
    car-nut Glenn
    conn.
    That is not doing anything to help you. It needs a good shroud.
  7. Cameron
    Cameron Member
    oklahoma city
    1977 Maverick
    like how? it was working properly before
  8. Dave B
    You need a real shroud, like the factory one, which directs the air thru the rad, or go to a electric fan.
  9. Cameron
    Cameron Member
    oklahoma city
    1977 Maverick
    Im just saying I have done nothing to the shroud and the set up hass been working fine until now. That leads me to belive there is another underlying cause. However, if the shroud is that bad and is the primary issue which electric fan shoukd I use or where should I get a shroud ?
  10. 71gold
    if you use a E-fan you will not need a shroud...
  11. Acornridgeman
    Wisconsin
    Curious ............ did it actually boil over? Or was the gauge just going up? At 250 degrees it should have been spouting like a whale.
    I've had overheats that really didn't get overheated - just a bad gauge or sending unit.
    I guess the key to me is why was it OK before and not any longer.
  12. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Late ignition timing will cause overheat issues.
    Is the "newish" water pump for a v-drive system, or the newer serpentine style that runs the opposite direction?
  13. mighty76
    mighty76 Member
    calgary,alberta canada
    76 maverick,58 ford f250, 79 f150 stepside 4x4
    Just looking at your pic. why is your temp. sending unit not hooked up ?
  14. Craig Selvey
    Before "what"?
    You definitely need the thermostat back in there.
  15. Cameron
    Cameron Member
    oklahoma city
    1977 Maverick
    I dont have a temp sending unit hooked up for water because I have a water gauge hooked up therefore I dont need it. My vehicle did actually spit out all over the place. And I have a v belt driven water pump. There is no issue with the actual temp gauge.
