Small Block Stroker Dyno completed
Discussion in 'General Maverick/Comet' started by Jimmy2gates, Feb 11, 2009.
  1. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Well folks my engine was completed and sent off to the dyno shop. After 5 passes on the dyno machine, the tester advised I needed a bit more valve spring as the valves were starting to float at 7000 rpm. He also said my carb needs a little bit of love to make it perform better ( larger air and fuel adjustment screws for more air and fuel). He feels that when these two things are corrected I will get 510 hp out of this engine. For now the numbers are in and at 6700 rpm I have 486 hp and 405 foot pounds of torque on 94 octane pump gas. The pictures of my engine are on my website and I will also post pictures of the dyno document to back this up by the weekend.I will also add a video of the dyno test by the weekend to my website for all to hear and see. Jimmy http://outlawjimmy2gates.shawwebspace.ca/ To see pics of engine go to top of the web page and click on the photo icon ,please leave a comment if you like ,thanks Jimmy
  2. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    Wow, now that's some HP.... But is that metric or SAE?:rofl2:How does the current exchange rate effect it???? For every 1 USA HP do Canadians get .82 HP??:cry:
    Sorry, I just couldn't resist...LOL
  3. yellow75
    Tillamook Oregon
    Well for just test runs without tweaking things your hp ratings are good I thought it would have a little more torque. Tweak the carb and get some better springs and you should get 500. At any rate it'll make a Maverick scoot right down the road or track.
    What heads are you using?
    Cost to build----a lot
    Seat of the pants feel-----priceless
  4. Jimmy2gates
    Jimmy2gates Member
    71 mav
    bump
    Ill try to scan the computer print out of the numbers on friday as i have to be out of town for a few days , Jimmy :yahoo:
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    good numbers for your first time out!
    Looking forward to seeing them once you get it dialed in.
  6. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Nice numbers! I bet you cant wait to get it in a car.
  7. courier11sec
    courier11sec Member
    Tucson, AZ
    Good stuff. as it breaks in and you get it tuned it'll only get stronger.
  8. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Nice run!!
  9. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Nice, which heads are you running?
  10. Jamie Miles
    Alto, GA
    I've had a few
    Details on the whole build?
  11. Dave B
    $10/hp???????
  12. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    nICE !!!!!!
  13. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Thanks Ray
    Courier11sec ,you where the one who helped me with this engine as it was you who received the stroker kit when i bought it and Bev(Grabbergirl719) picked it up from your home ,thanks Ray , Jimmy:thumbs2:,PS Hey Dave probably $12 or $13 per/ HP and that was being thrifty
  14. Dave B
    That's not bad still, looks like it should be well worth more than some peoples cars.
  15. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Monster hp
    Well guys ,i just showed my numbers to a friend of mine Jessica who was the B.C Bracket race points champion for 2008 in her 302 79 mustang 2 ,she said to me that she would like to see the build sheet cuz she said that i have pulled some of the most impressive numbers she has seen ,she said my power curve was huge ,i will try to put the sheets up tonight ,im pulling 450 foot lb of torque and 390 hp at 4500 rpm when my tourque converter engages.
