Small Radiator
Discussion in 'Technical' started by Bioinfomatic, Jan 22, 2009.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    I was wondering could i reuse my existing 250 I6 radiator for my 351w, will it keep the engine temp down?
    :hmmm:
  2. don graham
    I think you're probably going to need a bigger radiator. It's stretching it for a 302. I'd try it and see. If it works you're not out anything. :)
  3. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    No. usually 351s run hot anyways. Put a bigger rad in(y)
  4. baddad457
    Even the stock V8 radiator's too small or anything bigger than a 302.
  5. PaulS
    I agree, a larger radiator is needed when switching to the 351W.
  6. 72CometGT
    72CometGT Member
    Atlanta, GA
    Green 72 Comet GT
    As soon as I hopped up my 302 the factory radiator couldn't cut it any more. Had to go aluminum w/ electric fan. The problem w/ the Comet engine bay is there isn't anywhere for the air to go so the hot air just sits under there.
