Smoking
Discussion in 'Technical' started by 289, Oct 21, 2013.
  1. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    i just put on 100 miles on my break in here is what happened
    -its been smoking on me since it started
    -white smoke
    -i have true duels and the right smokes really bad while the left smokes a wee bit
    i thought maybe it was a head gasket leak but i checked and have 150 psi on all 8. Since its white smoke i was thinking i am burning water. but it does not over heat and im getting good pressure. i haven't lost any coolant though. could it be oil? the oil level HAD went down but i have a small pan leak so that's where the oil is going i think.
    i am using this old fuel cell i bought from a guy. it had some gas in it. he said it was normal pump gas in it, did not put in diesel or any race fuel. i was thinking it could be that old gas but it does not explain why one side smokes more.
    should i just run it out for a while and see what happens or stop because i might be damaging the cylinder?
    any tips will be greatly appreciated. thanks
    nick
  2. krelboyne
    krelboyne Remember
    Salem, Oregon
    It still could be water. Is the exhaust temperature noticeably lower on the side with the white smoke?
  3. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    ill check for that tomorrow. where do you think the water is coming from.....if that was water in the fuel cell....ima going to be pissed.
  4. rthomas771
    What type of sealer did you use on the intake gasket around the water ports? I seen silicon sealer leak when used in this area. Of course we are assuming that you're seeing white smoke...not blue/grey or black smoke
  5. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    its white as Christmas. i believe i used high temp silicone.
  6. iraceitall
    iraceitall Member
    Was a Comet
    Intake gaskets.
  7. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    ok ill check those out. probably not a good idea to drive it till i replace them, eh?
  8. iraceitall
    iraceitall Member
    Was a Comet
    I would advise against it. Coolant and oil make a nice concoction that eats bearings :(
  9. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    Thanks a lot! somehow i was thinking of ever option other then the intake manifold gaskets...makes a lot of sence now:)
  10. iraceitall
    iraceitall Member
    Was a Comet
    289/302s tend to be a little troublesome in that department.
  11. rthomas771
    Use Permatex #2 and throw the silicone in the trash.
  12. simple man
    simple man Member
    Bunnell,Florida
    One thing I will add is that if your car is an automatic trans, check the modulator vacuum line for fluid in it. Sometimes the vacuum is taken from a port that is more to one side of the engine, so it will get more fluid in one side if the modulator diaphragm leaks. Also this smoke is almost white! I'd give that a quick check before taking the engine apart! I would think if it was water, the level would be dropping. :)
