SN-95 Rear Disc Brake Conversions
Discussion in 'Technical' started by ultrastang, Jun 11, 2006.
  1. ultrastang
    ultrastang Member
    Arkansas
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    What size rims do these require?
    Thks.
    edit:Thanks for the answer
  3. ultrastang
    ultrastang Member
    Arkansas
    15" or larger wheels will fit over the 10½" V6/GT version rear discs, and 16" or larger will fit over the 11.65" Cobra rear discs.
    www.ultrastang.com
  4. maverick75
    wow thanks for the links
    how much is the bracket kit?
    and which kind of valve/master cylinder to use?
  5. ultrastang
    ultrastang Member
    Arkansas
    Hi Maverick75,
    The SN-95 V6/GT bracket version or the SN-95 Cobra bracket version is $150.00 which also includes the cost of shipping within the 48-states.
    http://www.ultrastang.com/images/2006/sn95bracketkit.jpg
    This is the MC I installed in a '65 Mustang fastback with the SN-95 V6/GT rear discs. The '65 had the stock 4-piston Kelsey/Hayes front discs, (and a power brake booster I installed from a '87-'93 2.3L Fox-body Mustang).
    http://img149.imageshack.us/img149/7765/v6gtsn95reardiscs0538gv.jpg
    This is the stock 4-wheel disc MC for a '94/'95 Mustang V6. Another possiblity is to use the '94 Cobra 4-wheel disc MC. Both of these MCs are ~7½" long from the mounting flange to the tip.
    Depending on whether you have a power brake booster or not, and depending on how thick the booster is, another MC I've used is the 4-wheel disc MC for a Lincoln Mk VII/Mustang SVO. This MC is ~ 8-1/8" long. http://img147.imageshack.us/img147/5390/mcfittingsspringwrap4oy.jpg
    I'm not exactly sure how much distance there is from the firewall to the back of the shock tower in the Maverick/Comet, but on a '65-'70 Mustang, you have a little over 14" distance in this area. For the early Mustangs, if the booster/MC is kept at a total combined overall length of 14", then it will fit within this space. You would have to measure on the Maverick/Comet to be sure how much distance you have, to determine what MC you could use.
    ...another 4-wheel disc MC possibility is to use the MC from a '67-'74 Corvette (ooohh! He said the "C"-word!).:slap:
  6. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Personally I am not fond of either of those brake set ups. Slides seize up on a regular basis and the internal parking brake mechanism unless used regularly tends to seize up as well. I think the Explorer Disc swap is the best overall choice. Parking brake is seperate from caliper and easily adapts to your currnet cables with minor welding. JMO but nice to see there are other options....
  7. maverick75
    thanks for the info ultrastang
  8. |MaverickMat|
    |MaverickMat| '74 Grabber
    Portland, OR
    1974 Grabber
  9. ultrastang
    ultrastang Member
    Arkansas
    I have an '03 Mustang Mach 1 (Azure Blue/5-speed) that has been my daily driver for the last three years and 68,000 miles. The '03/'04 Machs have the very same brakes as the '01 Bullitts and '94-'04 Cobras.
    So far, I haven't had a minute's trouble with any caliper slide or parking mechanism seizures. :)
    www.ultrastang.com
  10. ultrastang
    ultrastang Member
    Arkansas
    I'm unsure on this. I don't know how much room you have on a Maverick/Comet between the firewall and the back of the driver's side shock tower. On an early Mustang you have about 14¼" between the firewall and shock tower, so you would have to keep the combined booster/MC length ~14" total to fit the early Mustangs.
    You would need to measure your Maverick to know how much distance you have there.
    www.ultrastang.com
  11. Mavaholic
    I think Mavericks only have about 11" between the firewall and shock tower.
    How does the emergency brake work on the rear disc?
  12. ultrastang
    ultrastang Member
    Arkansas
    Wow. That's not a lot of room. Is this an actual measurement, or an estimation of the distance?
    On the Mk VII rear disc setup, all you do is use your existing drum brake cables to connect to the parking brake levers on the Mk VII's rear calipers.
    On the SN-95 V6/GT or SN-95 Cobra rear disc swap, you can either splice the SN-95 parking brake cables into the existing parking brake cable system, or you could use a custom Lokar cable setup.
    www.ultrastang.com
  13. Mavaholic
    I did measure it once but this is going by memory, which aint the best. :D I will double check it today.
  14. ultrastang
    ultrastang Member
    Arkansas
    Thanks, Mavaholic. I would appreciate that. --Inquiring minds wanna know!
    Didn't some of the Mavericks/Comets come with factory power brake boosters?
    If that's all the room you have with a Maverick, a 5.0L Fox Mustang brake booster definitely wouldn't work. That style booster is ~6¼" thick. Most Ford MCs are ~7-3/8" long (Lincoln Mk VII MC --same as Mustang SVO MC, is 8-1/8" long).
    The Fox Mustang 2.3L booster is ~4¼" thick. With MC installed, that would put the overall booster/MC length at ~11-5/8".
    IF the Maverick/Comets had an optional factory booster, it would be best to install the stock-style brake booster, rather than trying to adapt a booster from something like the Fox Mustangs.
    www.ultrastang.com
