so i tore it down what do you guys think?
Discussion in 'General Maverick/Comet' started by classic ccg, Jan 11, 2013.
  1. classic ccg
    ringgold GA
    72 maverick
    Ok my dad told me it came out of truck, then told me it came out of a 88 or 89 mustang, but it had a double stump oil pan. I have some pics.
    and the reason for all of this is i told it runs good lol so i try to turn it w a torqe wrench and it locks up have way
    ooh and he told me it was a ho lol so tell me what all od you guys see
      File size:
      586.6 KB
      103
      File size:
      376 KB
      104
      File size:
      424 KB
  2. scooper77515
    It is a roller motor. Roller cam. So it could be an HO.
    Find the casting numbers on the block and/or heads. That will help out a bit to determine the year model.
  3. billrogers
    billrogers Member
    hudson falls ny
    70 maverick
    4x4 trucks also use dual sump oil pans it does look like a ho motor if it only turns half way then it must of a little rust catching the rings
  4. Paul Masson
    1971 Grabber
    I thought the short block 302 and 302HO were the same. The difference, I thought was in the heads, intake, etc. If it's '87+ then it should have the E7TE heads and the 351W firing order.
    Pistons may have been different too, but not sure.
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    That looks like a truck short block because of the piston(truck motors have smaller cams and cast pistons with no valve reliefs)..... All Mustang roller 5.0's have forged or hyperutetic pistons with valve reliefs except for 86 which has a completely flat top piston with no valve reliefs.....
  6. classic ccg
    ringgold GA
    72 maverick
    I can't get the engine Id bc have of it is faded a way so I will look at the heads
    Where Are the heads id number but I was thinking of Geri Getting a new engine and build that one myself what do you guys think
  7. Dave B
    Even truck engines had E7TE heads, so you can't go by that.
  8. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Block numbers are cast into the block above where the starter would mount.1996 truck blocks were roller too,and pistons do look like truck pistons.
  9. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    :agreed: What He said ^^^^ :yup:
  10. Krazy Comet
    EVERY passenger car 5.0 is roller beginning '86 & that includes the Lo-Po used in the '86-'91 Crown Vic/Grand Marquis, as well as '86-'90 Town Car & '86-'88 T-Bird/Cougar... None of these engines had valve reliefs in the pistons because of the sunken valve E6 heads... HO were used in Stang, '91-'93 T-Bird/Cougar and '86-'92 Mark VII LSC... Earlier models of the std MK VII had std 5.0, around '89 all were HO...
    Trucks used a E5 or E7 head and AFAIK all had valve reliefs in the pistons, none were roller till '92...
    BTW the engine in question is probably one of the Lo Po 5.0, as those had dished pistons without valve reliefs...
  11. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Not that I want to do this but, most of the truck 5.0s were still not roller until about halfway through 93. I read that same thing all over the damn place, bought a 93 Bronco with a 5.0, then found out if I had wanted roller I should have bought a 94.
  12. classic ccg
    ringgold GA
    72 maverick
    Wow guys thank you for all your!
    Do you guys think it's worth building or find a better engine,
    I did get it for free so I don't have anything in it
  13. Dave B
    I bought a 93 E150, and it had a roller, and I bought it just for the transmission....
  14. scooper77515
    Build it! Nothing wrong with dished pistons. So you get 9:1 instead of 9.5:1. It will still make a nice motor, and just BEGGING for boost!
  15. John Holden
    John Holden Member
    NJ
    I don't think it's the 86 mustang HO because I although I agree those were the only year
    With no valve reliefs I believe the were flat tops and not dished. It's definitely a factory roller cam motor though which should be a good starting point for a build. Get some flat tops with valve reliefs so you can put some cam in it and gain a little compression.
