soild motor mounts
Discussion in 'Drag Racing' started by JHodges, Dec 18, 2013.
  1. JHodges
    JHodges thumper
    Dora Alabama
    Does anyone know anybody that makes solid motor mounts for a maverick. The rubber ones twist more than I like
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Do you like breaking transmissions?
    Richard Kuss likes this.
  3. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Solid motor mounts are fine, a solid trans mount is what will break transmissions.
  4. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    You could add a torque strap to control the twisting.
  5. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    I had solid motor mounts in my Mach I and I will tell you at 150mph the car felt like it was going to drive itself apart.
    Got rid of them!
    However, I did keep the solid transmission mount on my T56.
  6. rthomas771
    Might want to figure out how to pin the mounts with a bolt and nut.
  7. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    I am surprised that the don't make a polyurethane mount that is a good happy medium.
  8. John Holden
    John Holden Member
    NJ
    They do and they're adjuatable. I forget what brand they are but I have them in my falcon.
  9. JHodges
    JHodges thumper
    Dora Alabama
    I have solids on my mustang and never broke anything, polys on my Camaro with a poly trans mount and haven't broke anything running 6.90's in the 1/8. I don't care for your sarcastic tone so please don't post in my threads anymore. Everybody else thanks for the advice. I was trying to avoid using the bolt trick but if it comes down to it I will
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    And I don't care for your insulting hostility. I've done nothing to you. My comment was a result of a personal friend breaking 3 transmissions in his '68 Chevelle with a 383 "de-stroker" and a 4-speed, from running solid motor mounts.
    What ever crawled up your butt, it wasn't me, and I hope you can get it taken care of so that hopefully in the future you're not so touchy. :rolleyes:
  11. JHodges
    JHodges thumper
    Dora Alabama
    I remember your 1st post from this thread and took it as you being sarcastic, same with your post in this thread. Idk you may be a great guy in real life but you came off rude to me.
    http://mmb.maverick.to/showthread.php?p=986797#post986797
  12. rthomas771
    You have been lucky the transmission hasn't cracked with solid transmission mount and soft motor mounts. You can use 3 solid mounts without a problem.
  13. JHodges
    JHodges thumper
    Dora Alabama
    I have solid motor mounts on the mustang and a rubber trans mount. I was told if the engine mount is stronger than the trans mount you are ok. I remember when my Camaro still had rubber engine mounts I broke the trans mount and installed a poly trans mount I thought the floorboard was going to rip out lol
  14. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    AutoKrafters for mavericks has a nice torque brace for about $60 which I think I may eventually use on my car,bolts to the frame & mtr on the left side.What I like about it J is it has a threaded rod so it`s adjustable.
  15. Pony Express
    DelMarVa
    1976 Maverick
    Crazy Larry's comment could have been taken either way. His second post explained his reasoning which would have negated disagreement if it had been his first.
    Let's track together, gentlemen.
    While the solid mount on my transmission is stronger than the stock motor mounts, I've had no problems to date. And, the D1 spins the 335's relentlessly. I'm rolling as the boost kicks in, so not as harsh as dropping the clutch from a stop.
