Solid lifters on a hydraulic cam
Discussion in 'Technical' started by fastback86, Feb 22, 2009.
  1. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    What would happen if you had a late roller 302 block that was running a roller hydraulic cam, adjustable valve train, hardened pushrods, guide plates, heavy springs and decided to swap in a set of solid roller lifters? Is there a difference in the way the roller cams are made to be better suited to one type of lifter? I've always been curious about this.
  2. Dave B
  3. fastback86
    FL
  4. Mavman72
    It wont work well.Hydraulic cams are set up so the lifter preloads and takes up the lash on its own hydraulically.(lobes have a different profile/ramp rate) A solid cam relies on the lifter pre-load being set with the valve lash adjustment.Once again...different profile/ramp rate the two do not mix well.You will have a noisey valve train at the very least...and probably destroy the cam.
  5. starsky74
    starsky74 Technician
    Hackberry Louisiana
    I agree 100%
  6. don graham
    I heard that someone at the race track did that and had problems even before the first race of the year.
  7. 71gold
    ...solid-lifters-on-a-hydraulic-cam...
    ...hear-the-lifters-slam-slam-slam...
    sounds like the making of a country song...
    ...:rofl2:...
  8. baddad457
    I've heard of it done in a magazine test, they had no problems with it.
  9. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    People do it without issues depending on the cam material, but it is pointless to do. The hydro cam will have much less aggressive lobes that wont justify the extra noise, wear, and adjustment needed with the solid lifters.
