Some H.O. T-5 questions
Discussion in 'Technical' started by bigjay3115, Mar 22, 2010.
  1. bigjay3115
    bigjay3115 New Member
    indiana
    72 grabber
    Ive got a 88 fox/5sp donor for my Grabber/auto and I've been pondering on some things any help would be appreciated. I know there is a wealth of knowledge on this board!
    - anybody found a good spot to mount the ecu?
    - Think Illl have starvation problems under 1/2 tank with a 65 stang tank, Ron Morris sending unit and an in-line pump?
    - can I get by using the fox driveshaft to my 9"? same universal?
    - ok one more I want to use the harness from the fox and modify it to remove all I can from it. Done alot of research but just can find a good write up on it any tips?
    Thanks so much! ive got a few more but Ill save em. Ive got the dog houses of both, everything un-bolted and ready to start swapin parts. Boy really wish that the mav core support un bolted!
  2. mercgt73
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    An easy way to eliminate the starvation problems is to run a quart sized resivior between the tank and the pump. I learned about this from a book about swapping GM injected motors into Jags.
  4. bigjay3115
    indiana
    72 grabber
    Yea the ffi site has alot of info im just new to hackin up a factory harness tryin to absorb as much info as I can. As far as a resivior tank wont I have to run two pumps then? wish i could just use the fox tank under it.
