Some questions
Discussion in 'Technical' started by mav73, Apr 9, 2007.
  1. mav73
    mav73 New Member
    I'm from mexico city
    maverick 1973 289 engine whit 4 speed in floor
    some questions are stupid for you, but realy i need your help..
    first: I download the wire diagram for may mav 73, and chequed all the conections and repair some wrong wires, and find some switches for example the low brake switch (located in the brake pump) and change the stop light switch between the tail light.
    the first problem are under the hood, couse i found 3 wires whit conectors. one are the temp bulb, another are the oil presion switch and the three are one of the coil conectors.
    sound stupid but I don't find the temp bulb and the oil press switch some one tell me where are located, best if have a picture.
    some one have a diagram where are located all the bulbs, switches and fuses, relays in of the car?
    thank you for your help an sorry my english.
    En Español:
    Alguien de ustedes sabe en donde están situados el vulbo de la temperatura y el de la presión de aceite?
    Encontre estos cables con su respectivo conector debajo del cofre de mi maverick pero no encontré a donde conectarlos.
    Saludos.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The oil pressure sender is located next to the oil filter. The temp sender should be in the intake manifold behind the thermostat housing.
