Someone tell me...
Discussion in 'Technical' started by Jamie Miles, Apr 12, 2009.
  1. Jamie Miles
    Why I can't run '71-'73 Mustang spindles on my Maverick?
    I was thinking about picking up a set of the 2 inch drop spindles from Fatman Fabrications. Anyone tried running these on your Maverick?
    They list them for '65-'73 Mustangs and '60-'62 Comets.
    And I don't want to hear anything about cutting coils. I'm not interested. My car is a daily driver and I want to retain the stock ride and handling characteristics, and keep my tires wearing evenly. I'm willing to spend the money to do it the only way that I perceive to be right.
  2. rthomas771
    Don't know without seeing both spindles side by side. You could be opening up a can of bump steer if the tie rods angle is off. Mustang outer tie rods might correct the problem. Might not get a full 2" drop. My main concern is not if they will bolt up...it's how it is going to act going down the road
  3. Jamie Miles
    That's exactly what I'm getting at. I know they'll bolt up. But will they work.
    Why wouldn't they drop the car a full 2 inches?
  4. Bryant
    jayman did them. he posted about it about a year go. try to search for it.
  5. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    at one time fatman used to list a set for the maverick....
    others have used fatmans no issue
  6. Dave B
    Yeah, I know of a 70 around here running them, but they were worth more than the car? $1700 or so???
  7. rthomas771
    You said earlier this spindle fits '60-'62 Comets. The Falcon and Comet used the same spindles. When people swap to Granada brakes on a Falcon/Comet the front end will raise because the Granada spindle is 3/16" higher than a Falcon/Comet spindle. Some people clam up to 1-1/2" gain in height. (I think this is because the coil spring is not relaxed yet.) IF the Mustang spindle height is the same as a Maverick you shouldn't have this problem. That's why I said look at them side by side
  8. 69.5mav
    69.5mav Member
    Oregon
    I would think they would work just fine but you will have to use the 71-73 stang calipers since they are totally different than the mavericks.
  9. Jamie Miles
    I can get them for a little over $600 to my door. If they were $1700, I'd just do a Mustang II front end.
    These spindles use Granada calipers.
  10. Joe Dirt
    I looked at a 71-73 mustang and a disc maverick (76-77 model) int he junkyard a couple weeks back they looked darn close to the same to me?
  11. cmain125
    cmain125 Member
    arizona
    72 grabber
    i have the whole front disc brake from a 73 mustang it wouldnt work without the right calipers, spindles, master and everything i mean everything... cost about 500 with a good discount
  12. Jamie Miles
    This thread has nothing to do with using the brakes off a 71 to 73 Mustang.
  13. krelboyne
    krelboyne Remember
    Salem, Oregon
    The drum brake spindles on the early Mavericks (1970-72) are exactly the same casting numbers as on 1970 drum brake Mustangs.
    Jamie, is there a different drop spindle for the 1970 Mustang? or are they all the same 1965-73 Mustang?
  14. Jamie Miles
    It dosen't say...
    I'm going to try and call them sometime this week.
  15. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    71-73 Stang spindles, as well as most of the front suspension, will bolt right in.
    Therefore, aftermarket 71-73 spindles will bolt in.
    There is a chance that the manufacturer never really thought about it, so they didn't list it for a Maverick. Like said though, their aftermarket spindles will be set up to use 71-73 disc brakes... Therefore you need all the other brake parts to do the conversion less the spindles. They are big bearing spindles too... Like 74-77 Mavericks and all Granada/Monarchs. So if you are working on an earlier Maverick, the stock rims won't fit.
