Something is amiss..
Discussion in 'Technical' started by jpollard, May 31, 2005.
  1. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    Quick note on a problem I am having. My car pulls good up till 5000 rpms and then it pulls awesome. At the lower rpms (1000-5000) it seems to have a small miss...a slight burble or a minor malfunction. At 5000 and above the engine smoothes out and really starts to pull hard, then I have to shift. The carb is as tuned as I can get it, timing is great. It kinda acted like this when I was getting antifreeze in one of the cylinders but that is no longer the case (thank God and Trick Flow). I am thinking that my next course of action will be to check the spark plugs. I have swapped out a couple of fuel pumps also. Are there any other suggestions out there??
    Everything is new with only about 200-300 miles on it.
    77 302, Track Heat alum Trick flows, stock electronic dist, MSD 6AL ignition, Comp Cams, 6901 headers.
    JP
  2. igo1090
    igo1090 Member
    catonsville, md
    sounds almost like vac sec coming in too high. is it a vs carb? if so try a lighter spring.
  3. jpollard
    jpollard Member
    Montana
    Yes it is. Thats what I thought too....but does that account for the burble on the low end??
  4. stmanser
    Davenport, Iowa
    i wish mine pulled above 5000
    i am scared to run it over 5000....dont want to break anything,.,.
  5. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    Hey jpollard do you have adjustable rockers? dont know if you know this as you may already, i never really did until i started hanging out with my brother in law when he went racing his dragster. if you tighten your valves down to stock specs it will give you power in the high end and if you set them about a quarter turn past "tapping" it will give you power on the low end which is where you want it. as with the slight miss feel you may have a valve out of adjustment. hope this helps.
  6. jpollard
    jpollard Member
    Montana
    You may be on to something there.... I adjusted my valves because I was getting a lot of valve train noise. I turned them down another 1/2 turn. I suppose I should go through them all again and pull the plugs to see how they look.
    JP
