Spare tire question
Discussion in 'Wheels and Tires' started by mrmalina99, Jul 11, 2013.
  1. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    I was under the assumption that a spare tire for a 5 lug car should fit any year Mav/Comet. Can anyone confirm or deny this?
  2. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    The earlier 5 lug wheels will not fit the later disc brake cars. The center hole is too small.
    Lee "THE MAV" Richart:thumbs2:
  3. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Interesting, I might have to do some testing. We discovered the hole in the center on my spare was too small to fit a 74 drum brake car front. Craig pointed out it was not the original spare though.
  4. Craig Selvey
    1974 should have the spare with the bigger hole in the middle. That is what you need if you have a 1974 drum front end or disc brakes.
  5. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Just 74 or 74 and up? We were trying to put my 73 spare on a 74 without success. I have never acutally tried my spare on my car though.
  6. Dave B
    It's not just for the front, in 74 the hub on the rear axle also grew in size.
  7. 71gold
    I bought a '76 once and when I went to pick it up a tire was flat.
    I got a spare and when I went to take the flat off...someone had put an earlier year tire and rim on and I spent about 45 mins. beating...:smash:...the rim off the hub. that's when I found out there is a difference between disc. brake rims and drum rims...
  8. predfan2001
    I used to have a space saver spare for a Crown Vic so I'd have extra trunk space.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The rims don't mount to the hub, the center of the wheel does. :rofl2:
