Spark plug gaps... what do you recommend
Discussion in 'Drag Racing' started by stmanser, Dec 15, 2005.
  1. stmanser
    Davenport, Iowa
    yes i know... the numbers should be the same.. a friend helped me do these last time at SIR... i took them out.. he gapped them.. i put them in... i guess i should have checked them
    no wonder it ran like crap
    #1 .053
    #2 .051
    #3 .053
    #4 .051
    #5 .063
    #6 .051
    #7 .050
    #8 .052
    they are all kinda close to each other except #5.. .063 ???? WOW
    now the question is..
    what gap should i go with
    here is the basic setup
    9.5:1 pitsons
    bored .040
    477 intake 484 exhaust cam
    4 angle valve job 120# springs
    edelbrock performer intake
    edelbrock 600 carb
    MSD dizzy
    MSD 6a box
    MSd blaster SS coil
    MSD 8.8 MM Super Conductor wires
    the best i ran was a 14.5 at 95 last december.... the last time out.. november i think... i ran 15.1 at 93.. after these plugs were put in..
    i think the gap was .044 but i dont remember... my friend said that .050 would be better because i had the ignition that could handle it.. but turns out. it wasnt better...
    thanks for any help... i am buying new plugs tomorrow.. and i suppose i should get a good plug and gap it...
  2. mavman
    mavman Member
    Arkansas
    Increased gap increases the chance of misfiring. Decreasing the gap sometimes will allow fuel/oil to bridge the gap and cause a misfire, but that usually only happens at really small gaps, less than .020". I like around .035". On a high-boost turbocharged engine or nitrous engine, I like them around .025-.030.
    Depends on the ignition too. A GOOD coil with a GOOD ignition box will allow you to open 'em up quite a bit.
    In your case, I'd stay between .035-.045". That's a good starting point for just about any combination. Gaps aren't critical until you get to a certain point where the ignition simply will not jump the wide gap under a lot of cylinder pressure. (Did you know) at the ~1000' foot mark, a nitro burning Top fuel car is self-sustaining? The spark plugs are completely consumed. Only way to shut 'em down is to shut off the fuel. Once cylinder/combustion temps are at a certain point, the load on the ignition system is reduced drastically because it no longer requires as much energy to ignite the compressed mixture.
  3. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Now THAT'S fascinating stuff.
  4. cometguy
    cometguy Member
    Schomberg, Ontario, Canada
    72 Comet GT 302/AOD, 1972 Mustang NHRA Stock Eliminator 351C
    A lot of the articles I have read recommend a wider than stock gap with the MSD ignition or equivalent. I would suggest .040" to start. Buy a second set of plugs and increase the gap by .005". If performance improves, gap the next trial set at .050". Stop when the car fails to respond in a positive direction. We run the NGK plugs our 9.00:1 compression 6 cyl race motor at .045" with a 6AL ignition.
  5. stmanser
    Davenport, Iowa
    well i had champion v63c plugs.. and i was told that was too hot a plug.. and i looked at them.. they are black.. but i was also running 110 octane int he engine at the time...
    then i went to motorcraft plugs.. and they are all gapped at .040 and look white... then i went with autolites... the ones in there now... they are gapped as shown above.. and they are real white.. i am taking all the plugs to SIR satruday morning and have don look at the them..
    when i ran the 14.5 i had the v63c plugs in there with race gas.. i have heard about the NGK.. any particular part number to get?
    all the plugs are out right now.. so i am open.. i was thinking of runnint .040 and a nice hot plug.. the tank is almost dry.. so i am thinking 3 gallons of 91 to get me to the track and then i will get 5 gallons of race gas. see how that runs...
    people tell me i dont need race gas.. but i can feel the difference..
  6. stmanser
    Davenport, Iowa
    so any compression up to 10.5 should be the 50 -60 gap... wow...
    i sent MSD an email asking them where to start with my setup... hopefully i get an email soon
  7. stmanser
    Davenport, Iowa
    hey blown... looked at your pic and realized... if that is your car doing that, i am curious... did it hurt... looks like the car doesnt have more than 1 tire hitting the ground.. i bet you are greatful for gravity... or you might have been in space..
  8. igo1090
    igo1090 Member
    catonsville, md
    best way on this is trial and error/experimentation. start around .045 and make a run. up the gap .005 and make another run. see how it likes it. if it likes it,go up another .005 and make another run. you should reach a point where it doesnt run quicker or slows up or maybe stumbles a bit. go back to the last gap.dont forget to allow for weather changes whe judgeing effects.
    as a rule of thumb, larger gap helps bottom end and economy. smaller gap helps at higher rpm. find the happy medium which should be the largest gap which doesnt hurt the top end power. dont forget that plug heat range, fuel mixture ratio, and timing advance can all have an effect on which gap performs best.
  9. stmanser
    Davenport, Iowa
    engine gets hot... headers hot... hard to take plugs out and regap that often at the track... but yeah..
    i am going to get some new plugs.. gap them at .042 and try that out tomorrow at the track.. and take some notes...
    i just hope i get back into the 14 range..
  10. bmcdaniel
    Yep, trial and error to find your combination. With my Mallory HyFire box and a small shot of nitrous I have my plugs gapped at .054".
  11. stmanser
    Davenport, Iowa
    this is from MSD them selves.. saw this AFTER i gapped to .040 and put in the plugs
    Sir,
    We do not have a preference to plug brand, brand of choice. We do
    however recommend using one to two steps colder then stock and we
    generally recommend opening the plug gap up .010-.020 over what you
    normally run with a maximum of .065. The box will fire much larger then
    this but the energy required is hard on the caps, rotors, wires and
    plugs. We recommend using a standard style electrode non "HYPE" i.e.
    special coatings metals, electrode designs etc. Use a standard basic
    plug.
    Thanks,
    MSD tech
    i bought some accel plugs gapped to .040 and will run this tomorrow and see waht happens
  12. stmanser
    Davenport, Iowa
    ok.. so you took flight.. lol... did it hurt when it landed?
  13. stmanser
    Davenport, Iowa
    ko.. i just went and "test" drove the maverick to the gas station and back..
    all i can say is OMG.
    i cant wait until the morning....
    im gonna make a new time i think...
    we shall see
  14. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    that's not a Maverick!!!!!
  15. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    69 Camaro
