Spark Plug Questions?
Discussion in 'General Maverick/Comet' started by Jerilyn, May 23, 2003.
  1. Jerilyn
    Jerilyn Member
    Beautiful Las Vegas!
    1973 Maverick
    It is time to get some new spark plugs and when I went to the store there were too many kinds to choose from (boyfriend usually buys them) so I decided to ask what people here use? Last time I think I got the basic Champions. My mav is a 73 302. Thanks
    Jeri
  2. courier11sec
    courier11sec Member
    Tucson, AZ
    Plugs-
    Stay away from Champions.
    I wouldn't go with anything fancier than your basic autolite plugs though.
    I worked at a Schucks (AKA Kragen, Checker) for a few years and had more champions come back fouled or otherwise defective than any other brand.
    If there is nothing wrong with your ignition system, and your motor isn't too worn out, you don't need anything fancy.
  3. 1/4Mile Comet
    1/4Mile Comet Member
    Salina,KS
    I agree get autolite or motorcraft.:D
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I used to run champion in the race car. Switched to autolite platinum and picked up almost a 10th. I DO run the autolites.
  5. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    I have heard the same thing about Champions over the years. I have used Autolite and also Bosch with good results...
  6. Craig Selvey
    Motorcraft or Autolite. Get resistor plugs for no radio interference.
  7. Jean Doll
    Palmerton, PA
    We use Autolites in all our vehicles Never had any problems.
  8. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    bosh is a good brand
  9. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    anything but champions! i prefer (any kind of) platinums...i have 85,000 miles on them in my truck that says you don't have to change them unless it somehow occurs to you to do it. i changed them out at 85k thinking it MUST be time. no change in performance or gas mileage. using bosch right now.
  10. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Autolite and Morotcraft plugs work fine. The Bosch "Super" (NOT Platnum) work very well also and are only 99 cents each...
  11. jnord
    jnord senior member
    Tucson,Az
    1972 Comet 250 6
    Oh hell I gota get in on this. Nothing wrong with Champions, never had a problem with them. Forget Bosh; its no wonder they sold them for$.66 ea. u get what u pay for.
    Jan
  12. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Champion
    I've got to get in on this as well!
    I wouldn't use champions if they were the last spark plug on earth.
    I used them all the time, once... the hole inside of one spark plug came apart after 3 minutes of running. Beat the $*%& out of the piston and head on the drivers side then when across the intake to the passenger side and did damage there as well.
    This was on a stock Chevy Monza. I was helping a friend, some help I was.
    I called champion the next day and they said it was piston to valve clearance and maybe they were already damaged when I installed them, saying I did.
    Ok most of us here have installed plugs, how do you do that much damage to a plug before you install it and not know it? All I did was check the gap, and if I remember correctly they were all right.
    Champion said sorry Charlie you are SOL. Thanks Champion your fine product cost my friend a motor.
    HELL YES STAY AWAY FROM CHAMPION!!
    Autolite and Morotcraft, stick with what works.
    I guess this time I give a little more then just my two cents.
    Terry Gates
    AKA Bossmav
  13. jnord
    jnord senior member
    Tucson,Az
    1972 Comet 250 6
    OK: I've installed about a thousand or more Champions and have never had a problem due to a defective plug. The only way I know a plug could damage a piston other than being broken is by mabey having one that goes too deep in the combustion chamber (wrong plug?). Autolite and Motorcraft are ok too. Jan
  14. bossmav
    Harrisonburg, Va
    That was my first thought, same plug (by part number) that came out went back in. Champion even said it was the right plug for the car, go figure.
    Terry Gates
    AKA Bossmav
  15. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    Champions used to be poorly made a few years ago (offset electrodes, etc., just poor quality control), but they fixed that not too long ago. They are actually a very good quality plug now. On the other hand, a plug that is NOT good quality is the Bosch brand...whether you're talking platinum or the crappy "supers", they don't perform and they are poorly made. In fact, most Bosch products are so poorly made that they have been sued many times by Mercedes, BMW, .... I have seen them actually blown across the room on a higher compression 350 (not from contact either, mind you!). They make pretty good wiper blades, but that's about as far i'd go.
    Autolites, Motorcraft (which are made by champion, i am told by several reliable sources), Champion, and ACDelco's all run great in Fords. Just stay away from overseas brands and you're fine (including Accel plugs--made in china). I personally use the $1.99 Autolite platinums from CSK.
