sparkplug heat range
Discussion in 'Technical' started by Blue Brick, Sep 18, 2012.
  1. Blue Brick
    Blue Brick Member
    How do you identify the heat range for a sparkplug? Thanks!
  2. Krazy Comet
    Are you trying to determine the heat range of plugs you already have??? Generally the number indicates a hotter plug by using a larger number, a Motorcraft BF82 is a hotter plug than BF42, by the same token a Champion F-11Y is colder than a F-14Y...
    There are numerous guides on the net explaining differences in heat range but generally the the electrode and insulator will be thinner/smaller on a hot plug vs cold...
  3. Blue Brick
    Blue Brick Member
    Thanks....
  4. 74merc
    74merc computer nerd
    1974 Comet
    Not *quite* hijacking this, but when would you want to go hotter or colder with the plugs?
    I've heard a lot of round-a-bout answers, nothing that ever made sense.
    Colder plugs if you detonate?
