speedo gear help (I have the pertinent info)
Discussion in 'Technical' started by ptpdub, Jun 6, 2020.
  1. ptpdub
    ptpdub Member
    canada Sk.
    7 tooth driven gear, (I think) 3.80 gear set, 215/65r15 tires. wha t speedo gear (cable end) do I need? I have been reading other posts and still not clear on the answer.
  2. Shorty
    Shorty Member
    Lafayette, In
    This is the formula I used to calculate the difference between my original tires and the bigger tires we're installing now:
    #Drive teeth x Axle Ratio x Tire Rev per Mile divided by 1001 = Driven Teeth
    Here's an example: BFG 245/60R14 - Dia.:25.6, RevsPerMile: 813
    The math: 7 x 4.11 x 813/1001+ 23.36664335664336 or 23 tooth gear.
    I actually checked the accuracy of the speedometer with my Garmin and it was very, very close.
    You can get the tire rev per mile from Tire rack's site.
    Hope this helps.
    Bruce
  3. Krazy Comet
