speedometer and sunpro tach not working
Discussion in 'Technical' started by thelgfaud, Apr 2, 2008.
  1. thelgfaud
    thelgfaud Member
    NJ
    not sure what it could be, the tach was already on there when i bought the maverick. it looks like its hooked up from what i can tell, theres three wires going into the steering column.
    any tips where to start?
    also, when looking under the dash i found those two wires not hooked to anything, anyone know what theyre for?
  2. rayzorsharp
    All I can really tell you is that the wires hanging under your dash have nothing to do with the tach.
  3. Jamie Miles
    Tach:
    Red wire goes to switched 12V power source.
    Black wire goes to ground.
    Green wire goes to negative side of the coil.
    There should be a third wire for the back light. A lot of times it's white.
    Speedometer:
    Either the cable is broke, or not hooked up to the back of the gauge cluster. If neither of those are the problem, you need to pull the cable loose from the transmission and check the gear on it.
  4. thelgfaud
    thelgfaud Member
    NJ
    thanks, i actually just finished hooking up the tach right before i read your post. any suggestions on where to wire the back light in?
    i just checked the back of the cluster and it looks like the speedometer cable is hooked in so the tranny is next.
  5. Jamie Miles
    Look for a blue wire with a red stripe somewhere around the back of the radio. Check to see that it has power when you turn the head lights on. Hook the back light to that.
  6. thelgfaud
    thelgfaud Member
    NJ
    thanks jamie, got the tach all done and working.
    im gonna try and tackle the speedo tomorrow (well..today). can i check the tranny gear with the car on the ground? if so where do i look?
    sorry for the real basic questions, im sort of a newbie when it comes to the maverick.
  7. thelgfaud
    thelgfaud Member
    NJ
    anyone?
  8. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    You will probably have to put the car on ramps or jack stands so you can get underneath to check the tranny gear. It has one bolt holding a horseshoe shaped clip that holds the gear in place. Take off the clip and pull the cable and gear straight out.
  9. comet666
    comet666 RAISE HELL AND DRINK WINE
    Sweden/Gothenburg
    Comet -74 Inline Six 250, 4.1 AT
    Looks like the ones I hooked my stereo in to (not sure), if you follow the blue one up does it fit into the back of the the cigarette lighter..?
