speedometer gear question
Discussion in 'Technical' started by Dean Deeter, Dec 2, 2013.
  1. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    I changed my hogs head to a lower ratio. Now (as expected) my speed is off. I have been told that 1 tooth equals about 5 mph. But at what speed? When traveling at 50 mph, I show 65 mph. I have a 18 tooth gear. What do you guys suggest?
  2. Acornridgeman
    Wisconsin
    21 tooth is what I have done - red gear for manual and purple for automatic. Of course it all depends on what parts you have, gear ratio, tire size, ect.
    But with the speed off that far, I think a 21 will do it.
    Check this site out - there is a link to a calculator part way down the page.
    Hope this helps ............ :tiphat:
    http://www.transmissioncenter.org/Ford_Speedometer_Gears.htm
  3. Dean Deeter
    Dean Deeter Member
    Thanks for your help. I have emailed the site. The only problem with the calculator is I do not remember what the rear end ratio is.
  4. 71gold
    then...how do you know that it changed...may just be your speedo is reading incorrect...:huh:
    spin a rear wheel and count how many times the driveshaft turns to 1 revolution of the wheel...
  5. bmcdaniel
    Your 18-tooth gear is turning 30% too fast. You need to add 30% more teeth to slow it down to the correct speed. 23 teeth, if there is such a thing.
  6. dyent
    dyent Member
    vancouver bc
    Depending on what transmission you have (auto or man), you may also have to change the Drive Gear on the output shaft too, which would require removal of the tailshaft housing. Like the speedo gears, they come in 3 or 4 different tooth count and are colour coded, green, pink, black, etc., I can't remember all the different ones.......but as mentioned in an earlier post, you have to figure out what rear end ratio you have first and go from there.
    the combo I had to use with my 3.70 gears was 6 tooth Drive Gear and 18 tooth speedo gear with P235/60 14" tires.
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Your gear oil probably needs changed anyway. Pull the center-chunk and count the teeth on the ring & pinion. Then you'll know the exact gear ratio.
  8. Dean Deeter
    Dean Deeter Member
    The center I put in was from a Pinto I believe it was a 328? The speedo changed at that time. BM- you make sense about the 30%. I think I will try a 21 tooth.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Would not have been a 3.28. I'm guessing 3.00, or 3.40.
  10. Dean Deeter
    Dean Deeter Member
    Must have been a 340
  11. baddad457
    I saw recently in another thread, the 23 tooth gears are no longer available.
