Which color do I use with a stock 2:79 rearend gear and 15" wheels. I don't know the diameter of the tires. Thanks, Jerry
Even going from a 25" tire to a 26" makes only a miniscule difference. There's no need to change your speedo gear unless you change the differential gear ratio.
