Speedometer not working.......
Discussion in 'Technical' started by Moneymaker 1, Sep 19, 2013.
  1. Moneymaker 1
    Panama City Florida
    Ok I have I believe, figured out what's wrong with my speedometer, seems where the cable plugs in the back of it, it's not quite able to reach it, if I remember correctly, when I changed the gear down at the tranny, the cable ws sticking through it out the end of the gear, if I push it back some won't it just work it's way back through it again? any ideas to keep it there, I did notice inside at the speedo the cable seems to have a collar on it but it does no good being to close to the end. :huh:
  2. rthomas771
    When my speedometer quit working it was the gear's fault.
  3. Moneymaker 1
    Panama City Florida
    Wow, I would say so! I just put a gear for the four speed on mine, the cable protrudes through the gear, looking for a way to keep it from sticking through, something that would hold it inside the gear. :hmmm:
  4. rthomas771
    This gear broke after I swapped my C4 to a T5. The C4 gear has a 1/4" longer tip than the manual transmissions.
  5. Bryant
    the cable should not stick out the end of the gear. the end of the gear is usually sealed off to keep the cable from doing what yours is doing. sounds like you need a new gear. it may be a good idea to get a new cable also.
  6. Moneymaker 1
    Panama City Florida
    So if I just poke a little epoxy in the end of the gear it should work.:huh:
  7. 1973CometGT
    1973CometGT Member
    Orem, Utah
    1973 Mercury Comet GT
    Man, I would just change out the gear! Epoxy may work but it still isn't right.
  8. simple man
    simple man Member
    Bunnell,Florida
    I wouldn't trust that! I don't want to think what might happen if that hard piece of epoxy goes into the trans! :naughty:
  9. Moneymaker 1
    Panama City Florida
    Yeah ur right, I will go to Ford tomorrow.
