Spoiler instalation...rookie question #84926531
Discussion in 'Technical' started by mark_b, Oct 30, 2002.
  1. mark_b
    mark_b Member
    western PA.
    73 all original 302 2d red blk int. 72,302.2dr. green and 71 200ci. 2d green
    Ok...here it is. The trunk cap, does it require a special spacer or nut to fit in the concavity of the inside of the trunk?
    What size holes should I drill for the 4 studs?
    Thx, Mark
    :confused:
  2. Mavaholic
    You need to drill 1" holes and there is a special washer for it. If you dont have them you will have to make something up cause they are not available anywhere.
  3. Craig Selvey
    I have a jig I made up that you lay on the trunk and draw exactly where the holes go...and the right diameter. You can borrow it if you pay the shipping both ways so I can get it back.
    To hold it in, get 3" washers and bend them slightly to fit up in there and hold the spoiler on.
  4. mark_b
    mark_b Member
    western PA.
    Great help guys! The spoiler is now installed! Great fit too! Thanks Graig for the template offer! But I got it in!
    Made 4 simple "u" shaped spacers of a piece of "u" shaped steel.:D
