spooky turn signal
Discussion in 'Technical' started by 1970mavinator, Jul 25, 2009.
  1. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
    Ok, my right turn signal in my cluster always has a glow to it...the faster i drive, the brighter it gets. What could cause this? I know its not just the cluster, because I have changed the cluster (not because of this issue) and the first one did the same thing!:huh:
  2. 71gold
    ...bad ground...:yup:
    ...:drive:...
  3. 1970mavinator
    Ruskin, FL
    Hmmmmm.....That might also explain why sometimes my lights flicker......I hate electrical issues!!! Never know where to start!!
  4. darren
    ditto ground issue
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Mine were doing the same thing on the right side only. Front wouldn't flash, rear would but on both sides at the same time, side markers would flash with the right signal! Turned out something is wrong with the right front light assembly. Replaced it with a spare I had and now everything is back to normal!
  6. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    +2
    Check the ground at the front turn signal and rear tail light on the affected side. Also check the socket very carefully.
