sport mirror knob fix
Discussion in 'Technical' started by 14yearold, Oct 9, 2014.
  1. 14yearold
    14yearold Banned
    Virginia
    Any body have any tips on how to replace a broken sport mirror knob? Also bent cables?
  2. Krazy Comet
    I believe it is pressed in not much can be done, maybe drill it out...
    The ones for '69 are threaded in, but I don't think that applies for '70 up...
  3. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    I came up with a slick redesign of the mirror that eliminates the cables so that the mirror is adjustable just like the passenger side. Nice for Mavericks that don't have the knob hole in their door. I have a completely refurbished set I'm about ready to sell. I agree that it is nearly impossible to replace the broken knob. I have one that someone successfully uncrimped the cables from but you would have to find a way to remove the cables from your broken knob.
  4. 14yearold
    14yearold Banned
    Virginia
    OK, that really bites! I may drill it out order a new knob from npd, and add a dab of jb weld to the back its pressed it.
  5. rthomas771
    There's a trick in how to remove the knob. I think I saw this in a tech article on this site. The cables are color coded and it may take 3 hands to swap out the best I can remember
  6. Krazy Comet
    To straighten the cables I'd try lightly clamping a couple pair of Vice-Grips to the cable and bend it back straight... DONT clamp too tightly...
    Could maybe place bend between a couple blocks of wood and smack with hammer...
  7. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    Someone here replaced the knob by drilling it out and replacing with the threaded one. I am in the same boat
  8. Krazy Comet
    I hope it's a big boat as mine is broken as well, one of those little things I'm gonna get to...
  9. Acornridgeman
    Wisconsin
  10. 71gold
    ....:Handshake:...
