Ignition Module? Hi BadBrad, Kragen Auto Parts Online shows the same part number for the Ignition Module whether the engine is a 6 cylinder or an 8 cylinder. Hope this helps, BaldEagleMav
i didnt change mine and i had igntion problems when i first converted. i would recommend changing it, if its old.
My problem turned out to be my own stupid mistake. I stripped off the lil black insulator sleeve on my Accell suppression wires and that was it. I redid the ends and now it runs great. Here's what we built. 306 Cu. In. Hyperutectic Flat Tops (installed backwards) 68 Model heads, stock with 3 angle valve job CC 268H hydraulic DS II ignition Summit 1-5/8 primary long tube headers Profession Products Power+Plus CrossWind Intake 600cfm Holley VS Carburetor C4 shift kit 1800rpm converter 2.79:1 Open differentia; 8 inch
It's pretty strong. Needs some more gear and a posi! It just fries that ONE tire..lol. P245/40R17. I'm pretty happy with the way the engine performs. Still have a lot of wires and what not to tidy up then I will get to tuning on it and see what we can get out of it. brad
