stall converter and headers
Discussion in 'Technical' started by sam03rc, Mar 1, 2010.
  1. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    im ordering a ton of stuff from summit and might as well save on shipping and get it all together. what stall converter will get me close to stock with a little more high performance??? im figureing around a 2200?? and what headers should i get i have a c4 trans with a column shift???
  2. poil27
    poil27 Member
    longueuil
    I6 maverick 1970
    i know a place that build tork converter here i'm almost sure you will get a great price pm me i will give you his number
  3. sam03rc
    sam03rc Member
    gates county, nc
    can no one help me????
  4. Mavman72
    For headers with a column shift you need to use shorty headers...Doug thorley or Crites are the only game in town for the shorties that fit a mav. Or Hooker 6901 long tubes but...You will have to fab up a cable shifter set up to work with the column and long tube headers.
    As for the converter...Depends on rear axle gear ratio and HP/torque output of the engine and vehicle weight to determine stall range for the application. That said you probably wont get too many responses regarding converter selection unless you can furnish the above mentioned info...Good luck!!!
  5. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    sam b&m has some nice converters and as far as the headers hooker 6901s.i have a 2500 in my mav and i have the 6901s but i have a hurst promatic floor shifter with a cable so i cant help you there but i tkink they will work ok with the column shift.try doing a search on the headers i know others have asked what to use.hughes,makes pretty good converters to just stay away from tci converters.
    john
    guess i was wrong about the column working ok you could always put a nice hurst floor shifter in it.
  6. 71gold
    ...:disagree:...:whistle:
    just got my new...EDGE Converter...today...:thumbs2:
