Stallion progress update...
Discussion in 'General Maverick/Comet' started by A_Bartle, Jun 15, 2011.
  1. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    Been working on the Stallion clone, trying to get it done for the July roundup show. I had purchased an overflow tank to install a while ago, but found out that because this car has air, there isn't room to position it where I did on the yellow mav. Ended up making my own based off the style and design of the store-bought version. I used PVC and a couple of brass hose fittings. Here is how it turned out...
  2. A_Bartle
    Michigan's Thumb
    Also been working on the famous "lower dash" issues, resulting from a poor original design with many weak points. My solution was a combination of gluing in pieces of plastic on the back side (including small rectangle pieces in all the areas where the screws hold the dash in place, a common failure point), followed by filling in the cavities with fiberglass resin. End result appears to be very strong and solid...
  3. Ryan
    Ryan Ford Addict
    Phoenix Az.
    At first I thought the white overflow looked silly, then saw the pic of it painted and installed. Looks good in the car. And alot cheaper then the $40 aluminum tank I got. Nice creative work.
  4. A_Bartle
    Michigan's Thumb
    I used Krylon plastic paint, satin black....
  5. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Looks good and tucks in there neatly.
  6. maverick75
    It looks OEM! Cant get better than that.
  7. mavgrab302
    That is a neat trick for an overflow bottle, great job....
  8. don graham
    Looks good and I just bought 2 cans of Krylon satin black.:yup:
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Looking forward to seeing it. Love the overflow tank.
  10. MaverickLVR
    MaverickLVR takes longer then you think...
    Grand Rapids, Michigan
    1976 Maverick Stallion, 1967 Olds Delmont convertible, 1999 Harley FatBoy
    what am I missing? where are the pics installed? overflow bottle? :huh:
