starter sticks on
Discussion in 'Technical' started by tommyboy, Sep 13, 2005.
  1. tommyboy
    tommyboy 77 mav
    parkersburg west virginia
    1977 maverick
    can someone please tell me why when i start my mav the starter keeps rolling?seems like everytime i put something new something else goes bad:49:
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    The solenoid is bad. Just get a new starter, as they come with the solenoid and are only around $25.00 ...
  3. Mavaholic
    Either the starter is hanging up, or the solenoid is. Easiest wat to figure out which it is, is to take the starter cable off the solenoid, Then just hold it tightly against the post, get someone to start it, once its running and sounding like its dragging, pull the wire off. If it keeps running, you have a binding problem with the starter. If it stops, the solenoid is the problem, or the wiring going to the solenoid.
  4. tommyboy
    tommyboy 77 mav
    1977 maverick
    ok thanks guys so is the solenoid on the starter or on the fire wall its a 77 with a i6
  5. maverick75
    some have a solenoid on the starter but thats for extra torque they mean this kind
  6. tommyboy
    tommyboy 77 mav
    1977 maverick
    ok thanks i thought that was it just wanted to make sure ill go check it now ill let u know
  7. tommyboy
    tommyboy 77 mav
    1977 maverick
    ok went out and checked it and when i tried to take the starter wire lose it kept starting the car so a new solenoid was only like 8 $ so tomorrow i will give it a try thanks alot guys u are alot of help im glad to have a place to go and ask questions thanks tom
