Starts fine, than dies after five minutes
Discussion in 'Technical' started by Red 5, Dec 20, 2014.
  1. Red 5
    Red 5 Member
    1977 Mercury Comet 4.1L Inline six
    My comet has run in to a problem that has got me stumped. The car will start fine and drive for about five minutes, if it has been sitting for about three hours, but than it will sputter and die and will be impossible to restart for the next five, or more, minutes. When it restarts it will either run for about two seconds or it will run for about three minutes tops. At first I assumed it was water in the gas tank, but when I aded gas dryer and filled the tank the problem did not change. In addition if I turn off the car rather than let it die it will still not restart. In all cases I tried to restart the car both with and without starter fluid and it made no real difference. The carburetor, battery, and starter solenoid are all new and functional, and the alternator is also working. We have not adjusted the carb from the factory specs.
    It does not appear to be a fuel problem, I can blow through the fuel filter. Could it be an intermittent spark problem, if so how could I test for that, and where should I look for the source?
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    When the car dies, do you have fire to the plugs?
  3. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Is this an electronic ignition? Duraspark box may be giving up. May also be an overheating coil.
  4. Red 5
    Red 5 Member
    It is an electric ignition. I have not checked yet to see if I have spark when it dies.
  5. Krazy Comet
    Dieing/not starting when hot is almost always a ignition issue(loss of spark), the Duraspark electronic modules are famed for this problem...
    Maverocket likes this.
  6. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    ditto
  7. 71gold
  8. joee
    joee Member
    70 maverick
    runs then stops......sounds like crud in the gas tank .lines or filter
  9. rthomas771
    I had a problem with my engine dying randomly and everyone said it was the Duraspark box. I replaced the box and it didn't fix the problem. I changed the Duraspark ignition system to Pertronix and still had the same problem with the engine randomly dying. I replaced the ignition switch and it fixed the problem. I had the same dying issues with my Falcon and traced the problem back to a bad starter solenoid.
  10. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Fuel tank venting OK? Cause if it's plugged, the pump won't pull fuel against a vacuum. You could try running it temporarily with a rag for a cap...
  11. Krazy Comet
    Not likely if it runs OK after a cooling period, crud doesn't really care what the temps are...
  12. Bryant
    definitely sounds like the ignition system is over heating and cutting out. all the above ignition stuff is possible. you can either shot gun repair it by throwing parts at it, or test to find the problem.
    when it dies you need to disconnect the coil wire from the distributor cap and lay it on the intake or valve cover with some gap between the end and what ever its on and crank the motor to see if it sparks or not. most likely it wont. now you need to see if the duraspark box has power or not with the key on. if it does then most likely the duraspark box is the problem. if it doesnt then its a good chance its the ignition switch.
  13. Maverocket
    Northwest
    My second guess would be a plugged up sock in the tank. If the tank is rusty the particles build up on the sock as the pump draws fuel. When the engine shuts off the rust drops back into the bottom of the tank and it will run again. Had this happen on a Granada I once drove.
  14. joee
    joee Member
    70 maverick
    bingo..........
  15. Red 5
    Red 5 Member
    I'll check the ignition, and the starter. I replaced the duraspark box, and I tried replacing the coil, but so far the problem has not been solved. I'll also check to see if I'm getting any spark when it doesn't want to start.
