Steering Collar Swap - to floor shift column.
Discussion in 'Technical' started by dmhines, Mar 4, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Is it easier to just swap collars instead of the entire column when doing a column shift to floor shift conversion. It sure looks like alot of stuff to remove to take the collars off and on. Has anybody done it? Any tips?
    Thanks ...
  2. Craig Selvey
    You'll need snap ring pliers to remove/install the collars. I would say it would be the same degree of difficulty either way.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I swapped my upper collar years ago. Was pretty straight forward. Did not swap the lower collar, so I still have the holes where the shift indicator used to be, they are currently covered by the tach mounting clamp.
    Anyone have a lower collar for sale?:D
  4. av'smav
    av'smav Member
    Toledo Ohio
    74 maverick 302
    We went from a floor mounted 4 speed to a automatic on the column. At the time our daughter was 16 {her car} and she needed to keep her mind on the road and not worry about shifting and or GRINDING all the gears. Mike
  5. Mavaholic
    I think the collar is way more easier to change than the whole column. Everything can be done while sitting in the comfort of the drivers seat.
  6. dmhines
    Cumming, GA
    Have any detailed directions?
  7. Mavaholic
    Not really. Last one I did was about 3 yrs ago. It all just unbolts, not a big deal.
  8. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    So is it possible to find a lower collar without the holes? mine was changed from column to floor and it still has the holes from the old shifter up there. Pain in the butt to look at!
    I was thinkin about getting a roll of duck tape and just wrappin around there real nice (y)
  9. Mavaholic
    I always though of wrapping it with some thin gauge sheet metal and a couple of screws or pop rivits on the bottom. Once you paint it, no one will ever know.
  10. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    I guess that would work too, but the tape would be easier!
  11. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i filled mine with bondo, looks pretty good IMO. was still able to keep it, so you have to start the car to be able to shift out of park.
  12. maverick1970
    Missouri
    Dan you will need to pull the turn signal switch and wiring out of the column. Tie a heavy string to the loom when you pull it out then you can use the string to pull it back through when you putting it back together.
  13. dmhines
    Cumming, GA
    Well I was looking at the pedal mount project yesterday. Since I need to swap the entire pedal/column support out to install the one with a clutch pedal I'm gonna have to remove the steering column anyway.
