Steering column questions
Discussion in 'Technical' started by gmatthew76, Oct 29, 2011.
  1. gmatthew76
    gmatthew76 Member
    Freeport, Fl
    1976 2 dr Maverick, 1977 2dr Maverick,1998 Ranger, 2004 Focus Wagon
    I'm in the middle of swapping from a C4 automatic to a 4 speed top loader manual transmission. The column thats in the car now is for a automatic with column shift, and the trans i'm installing is a 4 speed manual with a floor shifter. My question is, can the column I have be modified to look and work like a manual column, or do I need to start looking for a true manual shift column?
    Thanks allot.
    :tiphat:
  2. Craig Selvey
    You can remove the pin holding on the chrome handle...and that will get you 90% of the way there as far as looks. I have also read where some members then cut off the "bung" that sticks out and then used bondo to fix where the bung was.
    Otherwise....you can look for a floor shift steering column.
  3. maverick75
    On muscle car(Spike TV) they did an episode showing just that. Cutting off the bug then welding a piece of metal to fill in the gap.
    Let me see if I can find the video.
  4. Nasty72Maverick
    Nasty72Maverick Member
    USA Midwest
    1972 maveric, numerous trucks and harleys
    you will also need to remove the steering wheel and remove the lock pin that locks the steering wheel and stops the the key from being shut off. Or you will be constantly grabbing the ring where the old shifter was attatched to to push it back gets a lil scary when rolling at a decent speed and you cant turn when you need to. I removed mine by pulling the wheel and just cutting the pin off.
  5. TOPORANGER
    TOPORANGER Member
    WISCONSIN
    Swap columns
    The cleanest fix is to swap in a floor shift column.
  6. Craig Selvey
    If you wire up the column under the hood where the shifter rod was once located, no real need to pull the steering wheel. Just wire it up so it doesn't move. Otheres have threads on here about doing this.
  7. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    The funny part is the floor shift columns have a hole in the side of them from the factory..:16suspect
  8. markso125
    markso125 Member
    Lewiston Ut
    The floor shifts are pretty much the same, manual vs automatic. The three on the tree column is different then the auto on the column too and it has its own problems.:cry:
  9. Dave B
    I drove my 74 Grabber for years, it was a column shifted car, that I converted to floor shift. All I did was knock the pin out, and remove the lever, nothing else.
