steering column?'s
Discussion in 'Technical' started by car-nut, Aug 24, 2009.
  1. car-nut
    car-nut Glenn
    conn.
    I am going to go to a floor shift in my Mav. I assume there were some floor shift columns out there in a Maverick? What cars do I need to look at? Would love to tilt as well.
    Any thoughts? Anyone selling one?
    Thanks,
    Glenn
  2. maverick maniac
    maverick maniac Banned
    owensboro ky
    200.00 shipped don't really want to sell but I guess
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    mines converted to floor shift with a column shift (column).
    I would not worry about it unless you building show car.
    Just remove all the linkage and the column shifter. My B&M shifter came with a nuetral safety switch.
  4. maverick maniac
    owensboro ky
    I agree with that statement ,,,
  5. car-nut
    car-nut Glenn
    conn.
    Not building a show car, but hate the look of a converted column.
  6. Dave B
    I did the same thing years ago in my 74, popped the pin for the shift lever, and pulled the indicator cover off, no one ever noticed.
  7. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I know what you are saying, but its not that offensive is it :)
  8. Rocco
    Rocco Member
    Chicago, IL
    1977 Maverick
    I don't think so. On mine, I went so far as to ground off the lever's "bump" and the column mounted tach covers the hole. Someone has to look pretty hard to notice what was done.
  9. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Saw off the "bump", grind it smooth, a little bondo and paint...
    Russ
  10. Columbus Comet
    Columbus Comet Member
    Columbus, OH
    that looks great Russ
  11. DaMadman
    Southern MD
    Maverick 1972,1970,1973
  12. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    Old street rod trick,did it many times,I also Tack weld the shift tube where the lever sticks out at the bottom,then cut the lever off flush,looks factory
