Steering column wiring harness question...
Discussion in 'General Maverick/Comet' started by mashori, Oct 21, 2011.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    What would happen if I disconnected the wiring harness that goes fro steerig wheel out. I am referring to the one that controls the blinkers and horn. Is anything else on that circuit?
  2. mercgt73
  3. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    I just replaced mine last month. I have a 3 speed manual on the column.
    Turn Signals
    Hazard lights
    Horn
    Reverse lights too (I think)
    Ignition too
    Its a pretty massive set of wires there.
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'm pretty sure ignition is not on there but I could be wrong.
  5. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    I could be wrong. I just don't remember any wires going down the column after I unplugged the big connector. Unless the ignition wires go down the center of the column. Ignition wires weren't really my concern at the time so I wasn't paying it much attention.
  6. Dave B
    Where is the wiring for the ignition switch?
  7. rthomas771
    The ignition wires are in the black plug above the grey plug
  8. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    Right! Now I remember. The big grey plug at the bottom of the photo is for the steering wheel (horn, signals, etc.). Disconnect that and you can pull the entire assembly out of the column. Slide the new one in, reconnect and put the steering wheel back on.
