hey everybody..i just put a new steering column in my car, and its aligned pretty straight...... heres the problem, when i put bolts through rag joint loose and turn steering wheel it turns fine, when i tighten the rag joint....it binds every half turn??? cars jacked up off ground
loosen the attaching bolts under the dash,install the rag-joint...then tighten the under dash bolts.....
