Step by Step Fuel Filter Change (in the tank) for Dummies
Discussion in 'Technical' started by gdemopesq, Mar 10, 2008.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    Under the tank on the drivers side, I see an access hole with hoses going into it. I am assuming this opens up so you can replace the hose and put a filter on it. What I was thinking of doing is lighting a cigar as I open it up...........Just kidding. How do I open it to repace the sock like filter in the tank?
    I think it makes sense as I am going to shortly put in a rebuilt motor, new carb and electric gas pump.
    So if anyone wants to give me a step by step for dummies, I would appreciate it.
  2. 71gold
    Drain...the tank...
  3. 71gold
    ...jack up car at least on that side...
    ...place on stands....
    ...chock wheels..
  4. Dave B
    And???
  5. 71gold
    ...removing rear wheel gives beeter accesss...
  6. 71gold
    ...remove plug...
    ...remove fuel line...
  7. 71gold
    ...remove locking ring...(with screwdrive and hammer)...
  8. 71gold
    ...be carefull with the rubber seal...you will need to lube it and replace it later...
  9. Dave B
    Pictures??
  10. 71gold
    ...you may have to tear the old sock off, i think they are glued from the factory...
  11. 71gold
    ...yes Dave, you may post pics...thanks :Handshake
  12. 71gold
    ...shake the float to see if anything is in it...if so replace it also...
  13. 71gold
    ...and...:huh:
  14. gdemopesq
    Michigan
    72 Maverick 302
    wow the answer is just like I wanted similar to those yellow dummies books
  15. Dave B
    I have a sending unit sitting on my work bench, beside a new tank ready to install, I just forgot to paint the straps :)
    I looked in the new NPD catalog, they have 2 sizes of those sending unit socks.
