still having troubles with the rear bumber
Discussion in 'Technical' started by highhillbilly, Oct 3, 2005.
  1. highhillbilly
    highhillbilly Member
    virginia
    1969.5 maverick
    i found the bolts in the trunk you guys were talking about,,but now it seems the clips that they go trough on the brackets have rotted,so the bolts just turn and i see no way of holding whats left of the clips to stop them from spinning while i turn the bolts,anyone have any suggestions,or am i going to have to cut the bolts,,,i really dont want to do any cutting ,but will if i have too
  2. Craig Selvey
    You can probably reach up in there with some vice grips and hold the nut clip nut that is spinning behind the bumper. I have done that and it works.
