stock manifolds with a mild 302
Discussion in 'Technical' started by maverick7072, Nov 10, 2013.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    I plan on putting factory manifolds back on my 70 mav im tired of all the header leaks my car is street driven ,I plan to run 2 1/2 pipe at the rear end with turn downs and flow master mufflers I don't know what cam I have but its lopey and has great throttle response with a rpm intake,600 holley and Mallory ignition will I hurt my performance a lot?
  2. Bryant
    it depends on your heads.
    if they flow well the manifolds will consume a noticeable amount of power. most 302s dont need 2.5" exhaust. 2.25 usually has better performance.
    a motor needs exhaust back pressure to run efficiently. chances are with the stock manifolds you will have plenty of back pressure and the exhaust pipe size wont have much effect on the motor.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No engine "needs" backpressure. There are plenty of threads and articles on that subject if you want to research it.
    2-1/2 inch pipes on manifolds with a 2-inch outlet kind of defeats the purpose.
    It will run fine with the stock manifolds, however power from 4000 and above will be reduced compared to headers.
  4. 71gold
    I say there will be...no difference... dyno it before any changes and then afterwards.
  5. baddad457
    Where are your headers leaking ? Gaskets at the head ? Or in the tubes themselves ?
  6. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    at the collectors
  7. baddad457
    What style ? Ball and socket or three bolt flange ? If it's the three bolt, what gasket are you using there ? The asbestos (white) ?
  8. John Holden
    John Holden Member
    NJ
    Before you go to the trouble of replacing your headers with manifolds and reducing your horsepower why don't you try some copper collector gaskets or aluminum or cut the flanges off and go with straight 3" exhaust pipe right to your header with a band type clamp like what summit sells? Then you can reduce to whatever size pipe you want to use.
  9. baddad457
    This is what I was getting to. Those white asbestos gaskets are about the worst thing you can use with headers, at either end. They WILL leak, if not sooner, then later. Soft copper or aluminum works 200% better and rarely ever leak.
  10. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i think it has the paper gaskets,i haven't done any of this work to the car the previous owner built this car im just changing a few things.the exhaust work is very crappy workmanship I, 2 3/4 pipe ran all the way out the back with those cheap rond turbo mufflers ,it was mounted up with crappy hangers it shakes and rattles against stuff that's a lot fo the problem I think ,either way I go a new exhaust system in the future.Has anyone heard of using som eflex pipe to help keep the stress off of the header gaskets? I talked with a guy who use to work in a muffler shop he said every car that he has installed flex pipe in the system hasn't had any more header leak problems ,he says install them as close to the header collectors as u can to keep stress off of the gaskets up top and down below
  11. 71gold
    he could move his timing 2-3 degrees and loose the same amount of HP...:huh:
  12. groberts101
    groberts101 Member
    Minneapolis, MN
    With a decent sized cam.. that motor will be down an easy 15-20 horse with restrictive factory manifolds. And what's worse.. you'll lose torque everywhere past about 1500 rpm. Fix the issues and go about enjoying tubular headers like the rest of us do. Remflex gaskets will not leak either.
  13. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    As far as collector gaskets go..i found most of them do leak..i tried a new carbon one about 2 years ago and keep using it, i think its 12 bucks for 2 gaskets and they never leak. mind you i took my exhaust off like 5 times since my first set and i keep buying them..that proves they are good ;)
  14. baddad457
    I use the soft copper or aluminum gaskets, no flex pipe in it, no leaks either.
