Straight Brake Booster
Discussion in 'Technical' started by Elephant, May 12, 2020.
  1. Elephant
    Elephant Member
    Katy, TX
    1977 Maverick
    Does anyone know of a replacement brake booster that points the master cylinder straight out of the firewall instead of angled up and in like it sits from the factory? My shock towers are about to be gone and I'd like to point it more straight to gain some more clearance on the inside of it.
  2. mojo
    If your removing the towers, most any booster will work.
    You might want to check this section on brake tech! Mavdog 71 has done booster on his Mav., he has lots of info on his conversion -- Might help ur situation.
    http://mmb.maverick.to/forums/brake-tech-articles.75/
