Stroker kits and sizes
Discussion in 'General Maverick/Comet' started by grabberguy16, Oct 31, 2011.
  1. grabberguy16
    grabberguy16 Member
    Courtenay, BC, Canada
    72' 2dr Maverick,70' 2dr Maverick
    I have been looking at different stroker kits and brands I'm just wondering what are fair prices for 347 or a 331 kit with flat top pistons. Some pros and cons between the too would be great too. Thanks for any help
  2. bmcdaniel
    I prefer a 347 over a 331. They cost the same to build, might as well get all the cubes you can. Last 347 I did, about seven or eight years ago, I got a Coast High / Probe kit on sale for $900. Cost almost another $800 for balancing and block work (hot tanked, magnafluxed, bored, decked, cam bearings, plugs, etc) Clearanced the cylinders for the rod bolts myself. Plus, depending on what parts you currently have or don't have, you may need to upgrade your heads, intake, carb, exhaust. Think of it more as a 351 instead of a 302.
  3. predfan2001
    Read up on sbftech.com. Many feel the 331 is a better bet.
  4. Resto
    Resto Benders Evil Twin
    Yuma AZ
    Ive looked at all the pros and cons. In my opinion I think the 347 is a great Motor, but I doubt they will last as long as a 331. Id read up about the angle of the rod at the wrist pin during rotation, on both motors. From what I read it seems to me the angle at that point on the 347 is a little severe causing more stress. Myself Im probably going to go with the 331. If I hadnt scored a free Mexican 302 Block Id probably build a smokin 302, but I felt this Block should be a stroker, why waste its potential.
  5. bmcdaniel
    Ancient wive's tales. There were many factory motors with theoretically worse rod angles and they last 100-200K miles.
    The ultimate, IMHO, is a big bore 347 or 363 using a dart block w/4.125 bore and a short stroke.
  6. Resto
    Yuma AZ
    Yupp thats a fact. Nuthin wrong with a 347, Great Motor. Im spraying a 150 shot on a 365+ Motor,with the heat down here Im just playing safe.
  7. starsky74
    starsky74 Technician
    Hackberry Louisiana
    im building a non traditional 347:cool:
  8. Bryant
    if your considering spending the money on a stroker, chances are your going to be abusing it anyways. so go for the 347. it will be more torquey than the 331.
  9. grabberguy16
    grabberguy16 Member
    I have did some research and found out a few different things. Most companies have changed there 347 kits so you don't have problems. For some reason most people gone with the 331. I'm thinking about the 347 but what kinda cutting or notching to the block do I have to do? Is it something I can do myself?
  10. yellow75
    Tillamook Oregon
    Yes Michael you could notch the walls for rod clearance but you are going to have to have the block bored anyhow so just let the machine shop do it, it should not cost too much and when they are done they will clean the block good. If you want the most out of the engine you had better think about some better heads :(
  11. predfan2001
    I hear 347 so much these days that I wonder how many really are 347s??? :huh:
  12. PaulS
    The 347 is the best there is for the stock 302 block....
  13. Resto
    Yuma AZ
    Yeah and like how many girls are really "Natural Blonds" never know till you lift the hood and tear it down.:biglaugh:
