Strut rod bushing removal
Discussion in 'Technical' started by fixmer, Nov 7, 2004.
  1. fixmer
    fixmer Member
    Maybe I'm just having a bad afternoon, but is there a trick to removing Mav ('71) strut rod bushings? I got the rods out, but I can only spin the bushings and washers...and they don't seem to be going anywhere!!! :mad:
    Also, do the available replacement bushing kits come with new washers (the big ones that cover rubber bushings)? I'd like to know before I start grinding on them if I can't figure something else out.
    Thanks,
    Denny Fixmer
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    They are in two halves ... Remove the metal sleeve going through the center and they should fall out ..
  3. fixmer
    fixmer Member
    The inner metal sleeve was flared on each end, so I just had to "unflare" one end with a screwdriver and chisel to remove it.
    Thanks
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    big hammer...
  5. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    The washers should be included.
  6. 71gold
    my bushings came with the washers on them....wrong side out :slap: ... i had to flip them over (y) ...frank...
    jerry, are you and the bride going to make ...moltrie swap meet this year?...the weekend before thanksgiving...
  7. fixmer
    fixmer Member
    Thanks for the help and info
  8. bmcdaniel
    :D I didn't have to do any of that, mine were so bad they fell off! :eek:
  9. Mavaholic
    I'll bet you still put the left rear on the right front and right rear on the left front.
  10. T.L.
    T.L. Banned
    Southern Colorado
    Mine were labeled as to front & rear. Got 'em at NAPA...
  11. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    i torched the rubber til it melted. it wasn't one of my days of much patience. :smash:
  12. 71gold
    dennis,
    you are going to make me go look...ain't ya...not!!!...frank...
