strut rods II
Discussion in 'Technical' started by Johng1970, Mar 7, 2013.
  1. Johng1970
    Johng1970 Member
    Freeport, PA
    Does anyone have a picture of the proper way to put strut rod bushings on?
    Thanks
    John
  2. rthomas771
    Here's mine
  3. Johng1970
    Johng1970 Member
    Freeport, PA
    thanks got new bushings came with steel bushing do i need to use it
  4. rthomas771
    Most likely because the old metal bushing is stuck in the old rubber bushing.
  5. Johng1970
    Johng1970 Member
    Freeport, PA
    sry, i meant to say that there is a metal cap over the rubber bushing. Do I need to use the metal cap?
  6. mojo
    The metal cap/washers go between the rubber and the nuts.
  7. Johng1970
    Johng1970 Member
    Freeport, PA
    I do know where the washers go but I have an extra metal insert that I'm not sure where it goes. I got it from Rock Auto and made by Raybestas.
  8. rthomas771
    Here is another pic
  9. Johng1970
    Johng1970 Member
    Freeport, PA
    rthomas has ruled again. That picture was exactly what I was looking for. You are a life saver once again.
    Thanks
    John
