Stubborn leaf spring bolt
Discussion in 'Technical' started by Comet4me, Jul 22, 2012.
  1. Comet4me
    Comet4me Member
    1975 Comet
    Help. I'm replacing my leaf springs and everything is disconnected but I can't tap out the front eye bolt. The bolt turns (with resistance) when I have a ratchet on it, but there is no room to tap it out from the threaded side. It is definitely captured in the rubber and I can't push it out either. I need some suggestions please
  2. Comet4me
    Comet4me Member
    1975 Comet
    Ok still trying stuff and nothing is working at all.
  3. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Did you try turning the bolt while applying pressure on the other end with a pry bar? U-bolts are out, right? Did you support the spring and move it around to find a position where its not binding on the eye bolt?
  4. Dave B
    Did you get the nut off?
  5. Comet4me
    Comet4me Member
    1975 Comet
    Nut is off, leafs not binding, ubolts out, tried prying while backing bolt out. No success.
  6. Mavaholic
    Might have to get a sawzall and cut the bolt on each side of the leaf spring. Done that before. When you put it back together, use lots of antiseize.
  7. Comet4me
    Comet4me Member
    1975 Comet
    Sawzall?! Ugh....can't I just WISH it out?
  8. Mavaholic
    LOL, you can try but the sawzall will be much quicker. There is a steel bushing in the rubber and once the bolt rusts to the bushing, they become one for life.
  9. Comet4me
    Comet4me Member
    1975 Comet
    So cut the bolt in between the frame rail and leaf spring, and also in between the outer bracket and leaf spring? Can I even get those bolts new to replace the cut ones?
  10. DavidEwers
    DavidEwers Member
    77 maverick
    Most good hardware stores will have those size bolts in grade 8
  11. Craig Selvey
    Yep....time for the Sawzall. I have had to do it many a time to a Maverick.
  12. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I had to cut mine off as well. Bolt was siezed inside the bushing sleeve.
  13. Comet4me
    Comet4me Member
    1975 Comet
    Time to call the rental equipment place. Don't own a sawzall. :(
  14. Dave B
    You can buy those bolts from Mustang suppliers, they have lock nuts on them also.
  15. Craig Selvey
    You can buy one pretty cheap from Harbor Freight.
