Stuck oil plug on third member
Discussion in 'Technical' started by mrcomet, Feb 6, 2011.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Anyone have any tips on removing a stuck oil plug on the third member. I am using a ratchet extension rod but it doesn't seem to go in far enough to get enough torque to twist the plug. Any other tool I should use instead.
    Its an 8 inch reer end............
  2. Bryant
    make sure its not full of dirt and grime. dont use an extension. you should be able to get the racthet in there. an extenion is alot more rounded off than the ratchet is.
  3. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    A good breaker bar. Thats how I pulled mine. No extension, just put it in there and lean on it.
  4. PaulS
    clean the inside of the plug out with a pick and brush, then use a long 3/8 drive breaker bar. I wouldn't use anything but good tools or you are likely to break the bar and bust your knuckles.
  5. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    Just use a ratchet and hammer. If it doesn't work, don't force it. You need to get a bigger hammer.
